I've been monitoring volts since I've noticed during WOT the volts would drop to 12.5ish. I've done the "Big 3" upgrade and even added a 1/0 gauge ground wire from the 270 amp Alternator mounting bolt to the engine block and it still drops volts according to the scanner. So today I checked the voltage reading off the Alternator mounting stud with the car idling and it read 14.6ish. Then I checked the battery, which is mounted in the trunk and it read 14.5ish. This is where I'm concussed, the scanner is logging Control Module Voltage and it reads almost exactly 1 volt less at 13.5ish. I also have a Autometer volt gauge and it reads 14.5.
My question is why does the scanner (ECM) read less than all the other test locations? I know it's not because of how it's wired because the ECM gets it constant power from the Alternator stud. The ECM is a P10 411 with a 12216125 Flex Fuel OS.
