Originally Posted by
Capt. Insaino
My engine is a 408 iron block with K1 Rods and Crank. Ceramic coated bearings and pistons, which are Wiseco. Dart heads that have been completely gone through by Brett Land at Land Speed Development.
This engine has been together and running for 5 years. About a month ago I ran it at the track on spray and it hit the limiter. The good news is that the nitrous shuts off at 6200 RPM's and the rev limiter is at 7k. I am not sure that plays any part of this, but I'm including it. I checked the valve springs, rockers, all looks good. There is no new noises from the engine. It still pulls damn hard, so I can't imagine anything happened to it. I have been working on LS engines since 1999 when I bought my Camaro, which I still own and is the subject of this post.
This car had great street manners and would idle perfectly all the time.
The issue is now, that it won't idle correctly. It will idle fine in park, but as soon as I put it in drive or reverse it almost wants to die. It started doing this after taking it to the track. Nothing on the car has changed other than install truck coils from a junk yard Yukon that I did BEFORE taking it to the track. I have tried both a new IAC and TPS, cleaned the throttle body as well. I reset the TPS and it will read .04 to .08% I checked plugs/wires.. nothing. The only thing I can see is that the front 2 plugs are a little black, I am running a super Vic intake. I have changed to truck coils with over 100k miles on them, but the car is not throwing any codes. I even unplugged a spark plug wire and it still didn't throw a code.
No one seems to be able to help. I am wondering if maybe 1 or 2 coils are weak causing this issue? Maybe after the nitrous runs something happened? I'm not sure. I am new on here, obviously... I have ZERO tuning experience, I have HP Tuners mainly for logging and changing out between my nitrous tune and N/A tune.
This is my last resort. No one has any idea what the issue could be. Also, I noticed my oil pressure used to be a constant 40psi at idle when hot, now drops down to 20-30 when hot, and once again I am not sure these two things are related. but I am including as much info as I possibly can.
I read the rules and included both my logs and my tune. I am not sure what a .cfg file is though.
So to sum it all up, I am hoping someone on here can look at my logs and I hope and pray something stands out that could be causing this issue. As I have said, this car has run perfectly for years, and now after a couple nitrous runs, it doesn't idle when there is a load on it, but idles good in park.
Thank you all for any help
