Interesting. I wanted to use this table as the easiest way to scale the injectors.
I don't see why this would cause any other problems. Run out of overhead on the processor? i wonder if there is a PID for CPU utilization. Try disabling misfire detection. It should help.
The car in my signature isn't utilizing the factory fuel pump anymore - it has a dual in tank squash setup... Come to think of it - since I mainly do this on 800+ builds to the tires - primarily because that's when it's really needed (high pd blower rpms running more than 16psi) - all the one's I've done this to have most likely had AM fuel systems with the FPCM no longer in the picture, but then again the Hennessy vehicles using this I'm almost certain were using factory pumps??? If I didn't state it earlier - I can say that you can not do this and modify other tables like your throttle DD tables at the same time - it will put the car into REP - only so much processing changes the ecm can handle...
~Greg Huggins~
Have you tried disabling misfire detection to give it some room?
