Hi everyone,
I have a 2001 LQ4 that has been swapped into an older car. It runs fine except that it never enters closed loop. I have checked over the MAT vs CLT table and have made sure that both CLT and MAT sensors are reading fine and are in the correct range where it should be entering closed loop.
Engine is completely stock with no modifications done besides disabling rear 02 sensors, CAGS, EGR, etc...
From what I can tell the fueling is almost dead on as is and the O2 sensors are reading very consistent. The rear 02 sensors have been deleted and COT has been disabled.
If someone could kick me in the right direction I would really appreciate it. I did not know about the option to force closed loop in VCM scanner so next time I am working on it I will try it and see what it does but did not try it during the datalogs.
I am still very much a novice with HPTuners so feel free to point me in the direction of any documentation or reading that may help explain what I need to change to fix this problem.
Thanks!
