Results 1 to 8 of 8
Thread: Connecting HPT MPVI to AEM 30-0333
    NC
    17
    As I cannot use the AEM via OBD since I have an 06 I moved the pins to the output of the gauge , but cannot seem to get it to come up In the scanner. Does anyone have any tips to get the gauge to show up in HPT (3.6).?
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    Which output? Serial or analog? Not sure I understand what you are trying to do but you can't just take the gauge analog out (Pins 9/10 connector A) or Serial (Pin 5) to the OBDII connector. You need to add separate wires with the analog out going to pins 1 an5 respectively of the MPVI green connector and if looking for serial, need to tie pin 5 to a DB9 connector pin 2 and aground to pin 5 and then connect that to a serial to USB converter cable. Run your transform in accordance with you selection of analog or serial.
    Ed M
    [email protected]
    NC
    17
    I'm sorry I wasn't very specific when I wrote that. I have my WB connected and reading in the channels section of the scanner but I cannot get it to display in the graph section. THATS what I'm trying to figure out.
    Oct 2011
    Australia
    175
    https://www.youtube.com/watch?v=3TQdrTMnljI
    https://www.hptuners.com/forum/showt...-PRO-Interface)
    Have a look at those two links, hopefully they can help you.
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Post log and current layout.
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    NC
    17
    thanks to your prior write up I got it figured out. I am having a MAP sensor issue wont show any reading past 105kpa and i know im over 200kpa THANKS AGAIN!!!!
    NC
    17
    6-26 cruise home.hpl
    her Is attached log see any issue????
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    What ECM do those run? And what MAP sensor are you using?
