Hey guys,
I'm trying to figure this issue out...
My car cold starts great. It warm starts great as well, as long as I start it within 5 minutes of turning it off...
As soon as it sits for 20 minutes or longer, it turns for a while then eventually stumbles to life.
I'm attaching my tune and 2 datalogs. In the first datalog, car has been sitting for 20 minutes and i start it. It takes several seconds to start, but once it does, I turn it off and try again. In the second datalog, you can see me start it up again about 30 seconds after the last start, and this time it starts right up.
My first thought process was that it was related to my IAT temps. The sensor is right at the throttle body and heat soaks easily. So i know the IAT temps are higher than reality. You'll see this as well because my AFR is pretty lean after it starts, but when my IAT comes down to what it really is, my AFR is on the money.
You can see in my tune, That I tried to adjust the airflow charge bias towards ECT at low airflows, hoping that would push it towards ECT based estimation, didn't seem to work though...
Edit: Problem found. Looks like it was my "new injectors". No idea why, but all I can think is that the injectors I was using were leaking. Bought new ID injectors (ID725s) and issue went completely away...
