Hello, I would like to get the VCM suite @$499 only if I can change the high/low cooling fan on-off temps without rewiring the PCM or fans. Everything I've seen makes it seem like it can simply be done through the tuner.
I've already used the Diablosport 30 day return policy(returned it the next day) when the intune didn't have the abilities to change my fan settings and I don't want to make the jump to HP Tuners if it's not an easy thing. I can just install a simple plug-n-play SLP fan switch and be done with it.
I am basically asking if there are any links to video tutorials or written guides to make this adjustment. I am fairly capable with electronic/mechanical things but software usually has a no return policy once its opened, so I want to be certain this will work.
The car is a 2001 Trans Am auto 100% stock -minus lid and 180 thermostat- and I'm trying to keep it mechanically stock.
Any input would be appreciated. Thank you.
