I would like some insight on how exactly this sensor works. There are four tables in the editor which are the slope and offset tables for both when the bypass is open and closed. From my understanding the computer uses this to help predict the pressure drop across the throttle blades and transitions from the supercharger to help reach desired torque from the ETC system and it switches and blends between the two tables as the bypass valve moves from open to close. I assume that since each rpm in the table has different slopes and offsets that essentially there is different map table for each rpm based off 0 to 5v. Am I understanding this correctly or am I way off in left field? Also it doesn't seem that very many people adjust these tables I could find very little information on the subject but it looks like it could be very beneficial to adjust these when changing to more efficient blowers.
