Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 108
Thread: HP Tuners - VCM Suite 3.6 Released
  1. #81
    st stephens church, va
    4
    sorry if I missed this. but are you able to flash the fscm now with this new update?
  2. #82
    Advanced Tuner axekick's Avatar
    Aug 2009
    Austin, TX
    333
    Is there no cylinder balance test?
    2006 Tahoe
    Iron ls2, built up 4l60e w/vig 3000 stall, 232/234 114, 4.30s, LTs, ORY NNBS intake and LS2 TB etc.
    Fighting solves everything...
    ...except partial differential equations.
    Click here to combine multiple VE Logs into one.
  3. #83
    Sep 2002
    Chicago, IL
    6,397
    There is not. The cylinder balance test was really only good at finding cylinders that weren't firing (wire/injector/plug/coil). All the test did was command a IAC position and then disable each injector one at a time.
    If you think you have a cylinder that's not firing and aren't sure which one, you can command a IAC, and then disable/enable each injector one at a time. If the cylinder is firing well, the engine will stumble more when you disable the injector. If the cylinder isn't firing, there will be no change when you disable the injector.
    We got this guy Not Sure, ...
  4. #84
    Jun 2010
    559
    What about the 2018's? I got a 5.3 6 speed try to read it and it only have the option to read the TCM no engine.
  5. #85
    Feb 2006
    South Carolina
    1,525
    Quote Originally Posted by 02Ls1 View Post
    You’ll need to request the beta from Support, most likely.
    Jaime
  6. #86
    Dec 2006
    OH-IO!
    43
    For 2017 Acadia Limited I had to have Internet access and try to read ecu. Tcu was easily read. Send message to support and had to send debug file. Said to try again and it worked.
  7. #87
    I wish HP tuners would focus on older diesels ecm. GM 96+ 6.5td , Ford 96+7.3TD and Dodge 98.5+ cummins vp44
    All of those ecm are able to be tuned have a large customer base but not supported by hptunners. I dont think HPtuners understand how large of a market there missing out on.
  8. #88
    Tuning Addict
    6,832
    It's my understanding that calibration support isn't necessarily the issue - the problem is the interface won't jive with the earlier ecms - I think they're still working on coming up with something, but don't know for sure on that one?
    ~Greg Huggins~
  9. #89
    Cummings VP44 is 98.5 to 03 I think. Cummings has a huge following. Those Ecms are not that old. Ive read they are looking into the 7.3 ford engines. Most diesel owners look to add a little power to their rig.
  10. #90
    Mar 2016
    4
    I am trying to change tire size using HP Tuners 3.6 software
    but it seems like it missing Gear/tire calc Option?
    can any one help me please
  11. #91
    Mar 2016
    4
    I am trying to change tire size and gear ratio using HP Tuners 3.6 software
  12. #92
    13,578
    What vehicle/computer?
    Did you click the edit tab yet?
  13. #93
    Mar 2016
    4
    04 Pontiac GTO
    Where can i find edit tap?
    when i click on speedometer it shows me just calibration and limiter option
  14. #94
    13,578
    C'mon, you know like at the top of the screen in the left hand corner like always.
    File, edit, compare, flash, tools, windows, help etc etc etc.
  15. #95
    Mar 2016
    4
    Oops!
    Okay now i found it i didn't expect it hidden right there, thank you very much
  16. #96
    Jan 2018
    11
    I am running 3.6.26 and I don't have the VIN wizard. Is there something wrong with it?
  17. #97
    Jan 2018
    :مرحبا:
  18. #98
    Jan 2018
    good
  19. #99
    Feb 2018
    Is there anyway to download this with Chrome OS?
  20. #100
    28,278
    Quote Originally Posted by johnrambo View Post
    Windows only. Sorry.
