Several years ago I installed a supercharger, extended MAP, long tube headers, injectors, etc. and had my 2005 LS2 dyno tuned using HP Tuners. Ever since then when I pull up to a stop light and start slowing down the rpms will dip down just before I stop and then come back up. Sometimes when I back up and stop it will die also. When the ambient temperature is above about 80 sometimes it will dip to zero and die, requiring me to brake and gas at the same time to keep it from dying. I know it has to be something in the tune that is cutting back the fuel while coasting down below about 5 mph. I've tried coasting down in neutral (I have a 6 speed) and in gear both and it still does the same. I've used the software to compare my tune with the stock tune, but am not smart enough to recognize where the error might be. If someone could take a quick look and tell me what is probably obvious, I would be very grateful! Other than the idle problem, it runs very well.
LG2-5 2 bar-dgc01.hpt Stock Tune.hpt
