Results 1 to 4 of 4
Thread: Boost Value Logging limited to 255kpa
    Sep 2014
    18
    I have a 2013 Camaro SS with a 3 bar map sensor. Currently​, I am only able to see a Max of 255kpa in my logs.
    I've read a few post where people have logged "low res" and created custom pids. I am unable to set up those parameters to log because they are not available for me to choose from. I cannot see them to select.
    Please advise.
    Nov 2009
    All Around
    3,149
    there should be 3 bar pid
    You've likely reached hardcoded limit of ECM at 255kPa. Are you planning on making more than ~22psi of boost? If so, you may need to do some fudging and lose some fidelity to ensure the highest boost is accurate for fuel delivery.
    Sep 2014
    18
    Yeah, the tune is dialed in afr and timing related. Just started​ to enter boost above 22psi, all is good on the log. Just would like to be able to log boost that high, rather than looking at my boost controller in the run.
