Results 1 to 7 of 7
Thread: 99 4wd ford ranger 6.2?
    May 2017
    6
    hey guys new to the forum. ive been building a truck the last few years. started as a 99 ranger with a 2000 suburban gen3 ls 5.3/4l60e drivetrain swap. Ran a painless engine harness and the factory ecm/tcm. Just finished a gen 4 2010 escalade 6.2 swap. Engine and trans running same harness and ecm/tcm just added lingenfelter signal convertor to change crank/cam signals to gen3. I am waiting for the hpt pro suite to show up any day and just throwing random questions out. Will the hpt be able to tune my factory 2000 ecm/tcm to work with signal convertor? Will the hpt work with whatever painless uses to flash the vats when my harness was flashed? Gosh...will it all even work? LOL! I know the original 5.3 was fun but this is gonna be more fun. Any help is much appreciated.
    13,559
    If your computer was first controlling a 4L60e, it won't control a 6L80e.
    You'd need to use a E38 computer to properly control the 6.2 and the 6L80e.
    May 2017
    6
    Not using a 6l80. Using the 4l60 that I had with my 5.3 swap.
    Apr 2007
    1,104
    im curious to see what mounts you used. I have a 93 ranger i have kicked around the notion of dumping the 2.3 turbo for an ls. The sad truth is, the l92, or gen 4 motors run so much better on the e38 ecm.
    93 Ranger. 5.3 D1X. 1069hp.
    May 2017
    6
    My lower mount is factory 3.0 Ford and the upper to the block is hand made out of a couple old chunks of scrap iron. Why does the e38 work better? Also I'm doing this as cheap as I can right now. I already had a painless harness for the original 5.3 swap. So I just used what I had. I work for a Chevy dealership here in town and the motor was going in the scrap truck so I figure why not convert back to gen3 and run the sh** out of it. It's just a sleeper 4wd ranger. Plus had a new kiddo a few months back and money is tight. Everyone's been there or is in my boat.
    Apr 2007
    1,104
    its a faster ecu, better processing and more over all control. in my experience, the ls3 series doesn't like the 411 style ecm.
    May 2017
    6
    Well that's not good stuff to hear. For now we gonna give it a try. If I end up changing to the e38 I would have to get a new harness as well correct?
