Results 1 to 12 of 12
Thread: MAF signal?
    Aug 2013
    29
    MAF signal?
    So i have less than adequate maf setup... can somebody look at the signal and tell me if im boned? the lb/min seems to be very shifty... i cant get the car as dialed in as i think it should be. If it helps ts a procharged 6.0
    13,559
    Is it like right at a bend or something like that?
    Does it have a screen in front of the MAF to try and help smooth out your airflow readings?
    Aug 2013
    29
    Unfortunatly yes and no.
    May 2016
    Adelaide, Australia
    246
    Where's the maf?
    We need a drive ability tech in here!
    Aug 2012
    SV, AZ
    447
    I'd like to recommend an SD tune. That's just a MAF mess right there. Or diameter changes, directional changes, no laminar flow screen, heat sink piping. Great candidate for a remote mount IAT in the manifold, adjustment of the MAT parameters and an SD tune. Just IMHO.
    Advanced Tuner ttz06vette's Avatar
    Sep 2008
    Charlotte, NC.
    242
    Abaco made a MAF that would help out immensely for these conditions as it was "tunable" to dampen the variation in air turbulence and average out the readings. Unfortunately they have gone out of business. I purchased a used one as a backup since without it I would need to go SD as well. Don't know if its worth doing a search for a used one or not. May be more hassle then its worth.
    Aug 2013
    29
    I'm going to get a flow straightener and either make a new pipe or fit it in the current one.
    Aug 2013
    29
    ordered a straightener. im noticing my st fuel trims in the graphs are great. but the WB signal is jumping all over the place and the long terms are meh... am i doing something wrong? could this be from the maf signal? Should i have ltft turned off?
    13,559
    To me it looks like the wideband is following the rich/lean of stoich pretty spot on, if you slow it down and use your mouse you can see it rise and fall just like the o2 sensors do.
    You can turn LTFT's off if you wish, many people do.
    Aug 2013
    29
    ill prolly turn them off. I should also add i get like a stumble, very briefly, but often, i can only assume this is from the maf. i mean correct me if im wrong but the signals should be basically smooth? looking at logs with the stock maf the lines are not nearly as jagged.
