Results 1 to 3 of 3
Thread: E-10 Stoich and Wideband Setup
    Feb 2006
    PAC NWest
    396
    With the overwhelming availability of E-10 I decided I should probably tune for it. So I've been looking at related threads and I see that the main stoich value should be set for E-10. Ok, but then I thought about the wideband, should it also be set to the same value?
    Australia
    1,978
    E10 is about 14.1 afr just set the WB to read lambda and u won't have to worry bout afr
    Aug 2012
    SV, AZ
    447
    I use 14.118932869 for e10. I also do all my tuning in lambda.
