Results 1 to 2 of 2
Thread: Wideband sensor on stock exhaust system.
    Jun 2010
    559
    Guys I've search around and found a lot of threads talking about where to locate the wideband sensor, before or after the cats.
    I have a 2014 Silverado want it to test the wideband and, I read that some put them before and some after the catalyst. Well I don't have to much room before the cats it's like 4-5 inches of pipe after the manifold and on my manual it says to install it from 12/15 inches after the manifold or it can damage the sensor to close to the manifold.
    What is the difference installing the sensor before and after the cats.
    Mar 2017
    Ft. Lauderdale, FL
    95
    Some folks say that installing after the cats will cause the reading to be off. That's never been my experience, however the one thing I do find is that the delay between when things change and when the sensor sees them IS increased when the sensor is post-cat.
    Unless you're trying to tune to the ragged edge, I don't personally find it to be worth fretting over.
    2007 Z06 (E38 ECM), stock LS7 short block, .030" milled/ported heads, PLX SM-AFR, MPVI Pro
