Anybody? How can you tell that it is getting PE now vs before?
Your commanded EQ ratio changed from 1.0 to .87. It's in your log. Would you like a screenshot?
Made some changes and seems better than before but still getting KR and I don't know why..Just cruising I will get it.
Any other thoughts?
Whats up. Been at the Ocean City Cruise all weekend. I will try to take a look at your logs tonight or tomorrow.
Daily Driver= 2003 BMW 330xi
Just met online another Marylander..Turns out he is friends with one of my buddies that runs at Capital. Guess never know who you will meet online and who they know.
Could TQ Management Drivers Demand Tables A-C cause this knock? This mornings log just cruising shows a lot of KR. I have upped these tables quite a bit from stock cause I love how the pedal feels, but wonder if it could be my issue. As seen in the log it is mostly at speeds of 70+
I took a quick look at "new log.hpl" and your getting KR above 70 kpa. Try enabling PE at 65 KPA if you can. Cant look at tune file right this second.
Attach current tune file also please...
here is my latest tune: I don't see anyway to adjust it per a certain kpa. If you see a way please let me know
Forgot to mention that I tried for my way home today lowering the tq management drivers demand to what my buddy uses and it did not help at all.
I just took a longer look at your log. Steady state cruise and KR? What all is done to this car?
my buddy from baltimore has the same mods and he doesn't experience this issue. His stoich was changed slightly where as i changed some of my alchohol multi tables such as injectors
Here is his stoich vs mine
14.75 14.75 14.75 14.24560546875 13.7412109375 13.23681640625 12.732421875 12.22802734375 11.7236328125 11.21923828125 10.71484375 10.21044921875 9.7060546875 9.7060546875 9.7060546875 9.35205078125 9.00244140625
14.68017578125 14.32275390625 13.97998046875 13.607421875 13.25537109375 12.92138671875 12.564453125 12.1904296875 11.83837890625 11.47314453125 11.130859375 10.779296875 10.421875 10.0634765625 9.7060546875 9.35205078125 9.00244140625
here is tune and log from this morning...Most of the issue seems to be cruising above 70mph...I even did some with cruise control on and still get KR
The fact that it doesn't show KR all the time at those speeds makes it harder for me to know what i need to do. I thought about pulling timing at the g/cyl and rpm range of the issue, but if i don't get KR all the time in that range i am not sure it is the answer. What about Injector duty cycle? How do i know if it is hitting its limits resulting in the KR?
Replaced my pass side wideband sensor today and now it pretty much matches my driver's side. Now to get it to stop kr
