Results 1 to 9 of 9
Thread: New Injector Question...
    Feb 2016
    Katy, Tx
    27
    After replacing injectors, where do i input injector flow info at? Do I plug that in injector flow/kpa chart?
    13,565
    If you bought injectors with data they tell you what tables you need to change.
    Injector flow rate vs pressure, flow rate vs volts, maybe an offset settings or two.
    Feb 2016
    Katy, Tx
    27
    These are FAST units and no data was sent...the only thing I know about these is they are 57 lb/hr @ stock pressure which i believe is 53-55 fixed psi..
    Senior Tuner Lakegoat's Avatar
    Jul 2012
    Florida
    1,459
    Find out who makes the Fast branded injectors and get the data from them?
    Here is something that I found from 2015 on here. I don't see the offset and min pulse
    MAP (kPa) 0 5 10 15 20 25 30 35 40 45 50 55 60 65 70 75 80
    Injector Flow (g/sec) 7.182 7.2416190562 7.3007512702 7.3594083773 7.4176016487 7.4753419168 7.5326395989 7.5895047192 7.6459469287 7.7019755252 7.7575994706 7.8128274076 7.8676676757 7.9221283258 7.9762171337 8.0299416137 8.0833090299
    If your fuel pressure is 43.5 psi then put these figures into INJECTOR FLOW RATE vs KPA table. 7.18 being 0 kpa and 8.08 being 80 kpa
    lse.
    2013 Silverado 5.3, 6L80k 8.8
    Feb 2016
    Katy, Tx
    27
    ok ill look into this... asap!!!
    Jul 2012
    Florida
    1,459
    Now that I look back at your post, I don't think what I copied is going to help since you have 55 psi fuel pressure. Looks like this is for 43#
    Jul 2012
    Florida
    1,459
    I found a couple of posts that say that the fast is made by Bosch. Maybe try somebody that sells Bosch?
    Feb 2016
    Katy, Tx
    27
    ok ya i thought the same thing when i saw the fuel psi you posted. i will dig into and see if i can get some info on bosch injectors. thanks for the info on this Lakegoat....
    Oct 2011
    11
    Did you ever find data for these injectors? I have the 57 lb ones as well and am wondering if the injectors are possibly hurting my power level due to them not having the completely correct data.
    2006 BOM GTO/Black/M6/17's H/C/I Car
    Thompson Motorsports Forged Aluminum LS2 Short Block
    Tick Polluter 239/244 .635?/.610? LSA111+2
    Patriot Performance Stage 3 Heads
    Fast 102 LSXR
    DMH Electric Cutouts "Cop Button"
    Duspeed Intake
    CXRacing Coilovers
    Hinson Polyurethane Motor Mounts
    Pedders Radius Rod Bushings
    26x11.5 Hoosier QTP's on 15x10 Racestars
    Spec Stage 3
    Pacesetter LTs Catless Mids
    Magnaflow Catback
    GMM Ripshift
    Mishimoto
    HP/TQ = 451/387
