I have a 92 Camaro swapped with an ls1 and t56 using a 411 ecm from an 01 trans am with a 1 bar sd os. My question is, is dfco possible without a clutch anticipation switch? I have been trying to get it to work, but then realized that I didn't use the switch for the swap. So I didn't know if was because of that or if I didn't have the map settings correct since it has a bigger cam in it.
Thanks,
Jay
