Results 1 to 15 of 15
Thread: Injector scaling id1000's / e38
    Advanced Tuner jpb1972's Avatar
    Mar 2015
    New Jersey
    271
    Is there any need to scale id1000's with the e38 pcm? I'm running the old HPT VE OS with big map.
    13,565
    If your injector flow table maxxes out at 63.5lb/hr then yes you need to scale it. Double the stoich, half the flow rate and IVT.
    Jun 2015
    NC
    201
    So when you say half the flow rate, you mean all the tables in there right? IE: multipliers such as flow rate vs volts, iat, flow etc...
    What do you mean IVT? Can you call out specifically the tables in full name?
    13,565
    It's just the Injector flow rate vs pressure table itself, you don't have to touch the volts , iat stuff.
    IVT Terms = IVT, it should be labeled in there.
    Jun 2015
    NC
    201
    gotya - thanks this helps alot
    Nov 2009
    All Around
    3,149
    depends on year of E38 08+ should be fine
    Mar 2015
    New Jersey
    271
    Thanks for the replies. I'm 2011, so I'm guessing I don't have to worry about the scaling.
    Nov 2009
    All Around
    3,149
    yea your good ^
    Mar 2015
    New Jersey
    271
    Quote Originally Posted by SultanHassanMasTuning View Post
    yea your good ^
    Tuner in Training bigwillys58's Avatar
    Nov 2008
    Springfield Tennessee
    20
    What does cutting the IVT in half do? Im asking because i have cut IFR in half and doubled stoich on my 08 GMC with ID1ks and havent noticed any thing odd happening.
    Jesse
    EDIT: I guess i should have mentioned that i have not cut IVT in half
    08 GMC rcsb 2wd. 4.8/4L80e with a dollar store turbo.
    best so far of 7.25 @ 97.4 1/8 mile
    Jun 2015
    NC
    201
    Quote Originally Posted by bigwillys58 View Post
    Jesse
    in for this info.
    Also this works at like a 25% reduction scale right?
    So for example flow rate vs KPA is multiplied by .75, same for IVT and then multiply stoich by 1.25?
    Nov 2008
    20
    Quote Originally Posted by itsdaveonline View Post
    It would but i think the value for your stoich table would actually be 1.33333 ( 1/.75 ) better let an expert chime in first before taking that to heart though.
    jesse
    Australia
    1,983
    IVT is base on AFR as well as other calculations so if u double stoich then the IVT thinks it super lean so its temp reading increases so if u scale it to the same as u do your stoich then it keeps it in check, if u multiply stoich by 1.25 then multiply IVT by .75 ect
    Jun 2012
    Denver, Colorado
    41
    There is an easy way to get around this.
    change the values in table (Flow rate Mult vs. Volts) the whole table is set at 1 change to the difference value between 100LB to 63LB
    so 100/63=1.587 set the whole table to 1.587
    Australia
    1,983
    Quote Originally Posted by Alfdhalah View Post
    the hard coded limit is 63.5lb and even if u use the multipliers it still limits to 63.5lb thats why u have to scale the stoich/IFR/IVT
