anybody know why the MAP would show 10kpa in the scanner all the time? KOEO and running, it's always 10kpa. i've tried simply swapping sensors, no change. two other pcm's, no change. i've tested for continuity from the plug to the pcm and all 3 wires were good. i've put jumper wires on the sensor and pumped it with a mityvac and it dropped in 1 volt increments about every 5psi like it should. i'm about to update my software just to rule that out, but i can't understand what is causing this. It's a 2003 silverado SS that the owner isn't happy with how its running. the map is obviously the problem, or at least 95% of it, but i can't see how every sensor and computer i have shows 10kpa all the time. what else could it possibly be?
calibration attached for reference
