Damn.
Idk.
Only other things I've noticed is,
- you don't have Cylinder Airmass selected in Channels so when you look at your Spark Retard in Graphs, you can only see 1 line (0.08g) worth of info instead of all the cells you hit (so it might help with the troubleshooting if you add it to your list)
- in your Spark Retard graph in Graphs, when you look at your SR max values ("+"), you get 0 knock from 0 to 1,800rpm, 2 degrees knock from 2K to 2,400rpm(/2,800) and 8 degrees knock from 2,800 to 4,400rpm. That might be a clue.
Other than that,
Compare your spark tables to your stock tune and other cars..
Make sure you didn't accidently put positive spark values instead of negative ones somewhere..
Check plugs and leads/wires for damage and make sure they're on tight..
Spool it up on brakes with your hood open at night to check for sparks..
Prey and wait for the HPT big dogs to help you..
I doubt your delayed/late-shifting trans is the problem or part of it. I'm pretty sure I don't get (false) knock from it and you're getting pretty bad knock from under 3,500rpm after minutes worth of low rpms and putting your foot down. Look at your log from 10:15 to 12:25
