I know... another noob with a rich injector story.
99 Camaro SS M6 - Stock LS1
SLP Longtube headers and loudmouth exhaust
Racetronix 255LPH in-tank fuel pump & harness
DeatschWerks 60lb injectors 18U-01-0060-8
NGK TR6 plugs .035 gap
MSD plug wires
MTI Cold Air
I went with the DW injectors because they have tuning data (http://www.deatschwerks.com/images/s...a%2018u-60.xls), flow matched and more reasonably priced than some.
I was expecting that I could just load the data into the Flow Rate vs KPA, Offset vs Volts vs VAC, Short Pulse Limit, Short Pulse Adder, Min Injector Pulse, and Default Injector Pulse - and have it run fairly well with an otherwise stock tune on a stock engine? For some reason, it's dumping way too much gas, starting off ~3ms pulse width, which is about what my 26lb injectors did, despite changing all of the injector tables? Once it gets past open loop, it pulls up to 30% from both banks, getting down to just under 2ms pulse. I assume that it should be 1.5ms or less? What's keeping it so high?
I don't have a WB yet, working on it.
The 60lb injectors are getting ready for the ProCharger. (;
Logs attached? What's the deal? I wouldn't expect to have to play with the VE or other air tables?
Thanks.
