Here's the ugly mess I'm in on a total Frankenstein deal that certainly not my doing. Here's what I'm working with.
95 Firebird with
6L LQ4 from a chevy van - mild street cam - otherwise bone stock.
700R-4 Transmission
MAF from a 6L silverado
DBC Throttle body
2001 ECM from a 4.8 Silverado
ECM transmission segment flash from an M6 ECM of same OS
So I'm trying to tune but when I go into decel and MAP drops the LTFT go through the roof (+25). Note this car does not have VSS so I really don't know if true DFCO ever gets enabled. Biggest problem is, if those trims stay, the next time I try to start it's crazy rich takes quite a while to clean up. I have tried to Limit the LTFT to 6 by setting Max Learn Limit to 1.06 or so but that function doesn't seem to really work. I've also tried a SD tune but same thing happens.
Anybody have an idea how I can work around this problem? Is it all because I don't have VSS?
Any suggestions are appreciated.
Regards,
Steve
