As far as I know I have everything inputted in the scanner config to log EQ Error but it will not log. I even tried to log AFR Error and that didn't work either. Since I'm using a Flex Fuel sensor I would prefer to use the EQ Error. Can someone please look at the attached config to see where my problem is? Thank you.
Primary Config.Layout.xml
Flex Fuel Test 14.hpl
