Hello, I just installed motor/trans and wired everything up, then checked the scanner and it always says I am always in "D4" and has "reverse inhibited". I think this is because I follow LT1swap.com wiring and removed the wires from the PRDNL (I left the 4-wire plug alone, and the 1 ground on the big plug as well), which may have been a mistake.
Will it hurt to run the trans like this? What will happen when I put the shifter into Reverse? or 1st?
