Helping a guy with his swap he bought a psi harness. 2001 tahoe p01 ecm 4l60e trans. i disabled anti theft codes and turned vats to none on system tab.
whats happening is truck will start then immediately die. injectors quit pulsing on scanner it shows 24ms on both banks for injector time. I plugged snap on scanner into it only code was a p1638 alt gen terminal. Did i miss turning anything off for vats tune attached?
