Results 1 to 5 of 5
Thread: Chart minimum
    Mar 2017
    Pittsburgh, Pa.
    46
    Chart minimum
    Back in the good ol' days all we had to work with was timing, fuel and air (for the most part).
    Now a days there is all kinds of cool stuff to tune an engine.
    What would be the most important things to have on the chart? Without the clutter.
    This is where I'm at now.
    God Bless America ! ! !
    Thank Jesus
    2007 Silverado NBS 1500 4x4 Z71 LT 5.3 4l60e
    Mar 2017
    Pittsburgh, Pa.
    46
    I can't find AFR cmnd, MAF, MAP.
    Thank Jesus
    Mar 2017
    Pittsburgh, Pa.
    46
    Think I found them.
    Under Generic Sensors
    Under Engine
    Under air flow
    Mass Airflow (mass flow rate)
    And
    Manifold Absolute Pressure (pressure)
    Then
    Under Fuel
    Under Commanded/Desired
    Air-Fuel Ratio Commanded
    Don't know why I didn't see them earlier. Staring at the computer to long.
    But I still would like to know what else is good, pretty please!
    Thank Jesus
    13,565
    Knock retard, injector pulse width and duty cycle. O2 sensors, fuel trims.
    I basically always run the default config for most things as it gives mostly all I need depending on what I'm doing.
    Mar 2017
    Pittsburgh, Pa.
    46
    Thank Jesus
