need help adjusting electric fan settings ? any idea were to set
System>Fans is where the parameters are
Daily/Mud truck1994 Chevrolet K1500 5.3 swapped, BTR STG 4 truck cam (224/230 .553/.547 111+2), 0.030 milled 243s, NNBS intake, NV4500, 37s
Project truck1992 Chevrolet C1500 single cab short box Big turbo LS, trucks are slow kk?.
any tips on setting on -off temps not sure whats a good number
i would look for a stock tune of a truck that had E-fans and compare maybe fine tune a little to your liking
If you are running a cooler thermostat you can set the temps cooler by a similar amount.
should I set the fans to serial cycling or analog cycling ?
Open the VCM editor and press the F1 key. Click "working with VCM editor", Click on "Parameters-GM", click on "Systems", click on "Fans".
Oops nevermind, they didn't bother to give info on that. They did define what on and off means good thing I would have never figured that one out.
Well go to the repository and download a 2005 Tahoe, they have electric fans.
So are your fans the normal on/off type?
Or are they variable speed controlled by a pulse width modulated signal?
Probably the traditional style fans I would assume.
My guess is recirculation fitted = fan#2. Type fitted = analog.
This is what I have my 2002 silverado pcm thats in my s10 set up. Two speed fans, they both work with these settings, it has no a/c.
