Results 1 to 6 of 6
Thread: E-85 Stociometric Reading On Wideband A/F Gauge
    Sep 2013
    Hello. I have a question about the A/F ratio readings I'm getting running 68% ethanol, according to VCM scanner. In open loop, my autometer sport comp. shows 14.7:1. In PE. mode it's around 13:1. Am I missing something here? Why would it be that lean in open loop? Any thoughts on this would be greatly appreciated.
    13,565
    Because it's still reading on the gas scale and your open loop for gas is still going to be 14.7ish.
    Tune in lambda if you want to run E85.
    Tuning Addict
    6,813
    Lambda does simplify things, but air fuel comes from lambda readings, so nothing wrong with using them... You just have to realize that because your commanding different stoichiometric values doesn't mean that the car is going to run at those values - they're only there so the ecm can adjust the quantity of fuel to achieve the same burn... You can even keep using air fuel error with some work to the math equation for the changing stoichiometric and alcohol values...
    ~Greg Huggins~
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Quote Originally Posted by Blackhawks1 View Post
    Lambda lambda lambda. Widebands don't actually read AFR.
    /deadhorse
    Tuner in Training b2319dragracer's Avatar
    Jul 2013
    Dundalk, Maryland
    25
    So how do I make my readings in Lambda?
    Moderator
    Mar 2014
    Raleigh, NC
    6,347
    Change the transform for the external input.
