Does changing the firing order in the tune not work. Ended up having to swap pins at the ecm. I thought changing it in the tune worked in 2.24.
2001 Jimmy ,L31 with marine intake,CPC conversion,Nv3500 5 speed,SAS,Dana 44's front and rear,4.30 gears..
No one knows.
Firing order in tune is for misfire recognition. You have to manually repin the harness, then set firing order in tune so misfire monitor correctly identifies the correct cylinder in the event of a misfire
Michael Bray
Rusty Knuckle Garage
Slidell, Louisiana
20yr Master Tech.
Advanced Level Specialist
GM World Class Technician
Shop Owner
