2007 LS2 swap into 240sx using 2001 p01 ecu. Can't find injector values anywhere. any help? I've put a bandaid on it to get afr for cruising and WOT in Ballpark but would really like to do this right
Look up a stock LS2 car from the tune repository if you need the data.
There might be some slight number fudging if the tables don't look exactly the same but so long as they are close to showing they are 33lb/hr it should work out good.
thats what i had done. i multiplied the flow rate by 1.15
