Results 1 to 4 of 4
Thread: Open loop lean
    Mar 2017
    22
    Open loop lean
    Is this a good way to get a lean cruise? Other than the fact of to lean and melting things but it's a DD and I'm looking to get a little mileage out of it but want to keep it reliable. Stock 6.0 in an 02 Denali.
    Another thought I had was changing the stoich setting from 14.7 to 15.5 or whatever would the O2's work accurately at that lean of value?
    13,559
    Not worth it.
    I see no point in putting the truck in open loop all the time, that is the only way that you could get it to run leaner all the time. Losing closed loop functions on a daily driver isn't what I'd do. You a just limited on what you can do with a heavy 6.0 truck and AWD. Getting the MAF/VE dialed in and maybe slightly touching cruise timing could help you out but most of it comes down to driving habits.
    Mar 2017
    22
    So with tuning the VE do you reccomend using the afr error or the fuel trims? Ive seen both ways and wonder which is best.
    13,559
    If I had a wideband in the exhaust already, I would use that over the fuel trims method. Otherwise it comes down to what I can do at the time.
