Results 1 to 12 of 12
Thread: Narrowed The Wideband Choice Down to Two
    Mar 2017
    19
    Here is what I have come up with for wideband choices:
    Zeitronix ZT-3 w/ ZR-1 AFR and Lambda
    Innovate LC-2
    What do you fellas think between those two?
    2000 SS M6 MTI T-1 Cam, Random Tech Catback, Cutout, Aftermarket Lid, Under Drive Pulley
    2012 CTS-V Stock (Fast enough to peg my pucker factor limit)
    13,565
    Is neither an option?
    The new AEM's are really nice, one can even use the can-bus system to work with hp tizzles.
    Senior Tuner mowton's Avatar
    Mar 2007
    Florida
    3,773
    ^^^^^^^^ AEM 30-0330 with the serial and analog pins/wires added....triple duty :-) ....my choice as well....
    Ed M
    [email protected]
    Mar 2017
    19
    The AEM looks like a viable option also: the software is really nice
    With regards to the AEM sensors, do you have any recommendations?
    Basically, I will be hooking the sensor up to the stock LS1 exhaust system for now. In the near future, I'll be installing TSP headers and a TSP y-pipe with Cats and will have to swap the sensor around.
    Thanks!
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    ECM brand.
    http://www.dsxtuning.com
    Just say no to bull s***.
    Mar 2017
    19
    ECM brand.
    Stock GM 2000 LS1 ECM
    Mar 2017
    19
    Quote Originally Posted by mowton View Post
    Ed M
    Ed, I have to say that is one slick AEM configuration/installation: very clean!
    Cheers!
    13,565
    ECM brand is an actual brand that makes widebands.
    They aren't what you call cheap, dyno/lab grade type stuff that the real pro's would want to use.
    The AEM stuff works great for us joe blows out where just fucking around with our cars. It's good enough for the chicks I hang out with.
    Mar 2007
    Florida
    3,773
    Quote Originally Posted by sawacs View Post
    Cheers!
    Thank you sir....was thinking of packaging and adding to our line :-)
    Ed M
    [email protected]
    Mar 2007
    Florida
    3,773
    The problem is the quality level jumps from $300sh directly to $1500/$3000......no in between. I have an LM1, LM2, LC2 and now the AEM......guess if I just sprung for the Lambda Pro in the beginning, I would be even :-)
    Ed M
    [email protected]
    Tuning Addict
    6,802
    The 30-0333 is pretty close to being as good as the super expensive lab grade ones that I use... I still haven't set mine up with the analog additions which is supposed to be quicker logging than the can protocals... Once that is done, I'm hoping it logs just as good as my lambda pro... Right now the lambda pro registers transitions better than the AEM's...
    ~Greg Huggins~
    Mar 2017
    19
    Ed, you should package that up: I think something nice and clean like that would sell.
    I finally made the decision, after talking with AEM, to go with the 30-0333 OBDII setup along with the clamp mount rather than weld a new bung on. Although I will need to run a couple of extra wires for use on the 2000 model LS1, I can still utilize the setup with my cts-v which is a win win
    I am having TSP headers and a catted Y-pipe installed in a couple of week so I'll have the shop add the wideband sensor during the install (finally after 17 years of thinking about having headers installed on the SS, I am finally going through with it )
    Cheers!
