Hey guys.. just wanted to throw this up here to illustrate an issue i've been seeing tuning my 2.3 Focus RS. This rom was created/logged specifically to show the issue as clear as possible, and I'll try to break it down as best as I can.
Basically, even with no visibly active limiter and actual load < desired load, boost below the maximum etc it's still shutting the throttle and preventing load targets from being reached. It's almost as though there is some airflow limit or something that I just can't see. This issue is intermittent, it seems. Sometimes it'll spike boost (that's what i'm trying to fix) then quick bring the load right in line and hold exactly what i ask.. other time is just hangs out around 2.5g/rev with the throttle mostly shut. I'm at a bit of a loss with this whole 'correcting for overboost from a catless downpipe' thing, as nothing seems to really do what you'd expect and it's not very straightforward :/.
Anyway, log and rom is attached. Maybe someone will see something I missed. Thanks in advance.
load-issue.hpl
HRI-base.v70.hpt
