Track only fox body 2500lbs
1/8th mile bracket car. runs 7.40s at 97 mph. (SD Open loop / no O2s)
lm7 stock bottom, 706 heads, tunnel ram with 102 TB, MS4 with double springs, 3inch fender exit headers.
powerglide, 4.88s with 28x10.50 slicks.
i know this tune will not look street friendly. just need it to scream for 6.5 seconds. I need more torque in the 3000-4000 range.
upgraded to a 5500 stall conerter that is a little tight. which is great, but i cant break through it on the transbrake. stuck around 3400 .
anything you see would be helpful. my 60' is horrible (like 1.89 horrible). if i can get higher on the converter, Ill be in the mid 6s. dont want to loosen the converter just yet, cause it will be awesome if i can somehow hit the 2 step between 4-4500. I do have a healthy wet shot on it, but prefer to run the bracket natural. not looking to change out or modify heads just yet. want to see what it can really do out of the box.
just replaced o2s, and went closed loop today. still running SD.
