Results 1 to 6 of 6
Thread: strange issue ETC% and idle error
    Tuner in Training fastlsxs10's Avatar
    May 2015
    33
    Hey guys , car is my own 2008 g8 , Im having a weird issue with scanner v3.4 , the car refuses to log both the idle rpm error and the idle desired etc % , never did this with the older v2 scanner ...Im trying to set raf and need these obviously for that purpose .. attached a copy of my configuration file any help is appreciated .
    Tuning Addict
    Jan 2015
    6,802
    Repoll for supported channels then look through to see what channels pertaining to this are actually available... If they're not there - contact support - they can probably add them for you...
    ~Greg Huggins~
    May 2015
    33
    repoll'd neither is there or anything close and I set up a config to poll just the throttle itself with the basics ..still nothing... but I do get it in graphs and charts it just doesnt give me any kinda numbers because im not capturing whatever its looking for
    ..I swear it seems like every update makes it that much harder to tune the fundamental things. v2.24 was arguably the best version imho
    13,565
    If anything, redownload the 3.4 version from today and try again.
    Throttle percent should always been there on a G8, haven't seen one where it couldn't get added. Even viewing other people logs on here and I've seen it too.
    Just remember to "not" click the gear icon when searching for channels.
    May 2015
    33
    tried that too ^ I get polling throttle % before and after v3.4 but still no idle error rpm and no idle desired ETC % ...I get the option in charts but its not giving me any readings for either
    Tuning Addict
    Jan 2015
    6,802
    Are you working on a gen 4? I honestly don't remember there being an idle error rpm pid? I always use the spark correction on them... If they were there for gen 4's in 2.24 contact support - they may just need to add them to you particular vehicles OS in the scanner - I've had them do this for others in the past...
    ~Greg Huggins~
