Just curious what others run for AFR on there two step/launch control? Also what timing are you running and how much boost do you build?
I am at 15-17 AFR with 19* timing at 4300 rpm at 105 kpa. Idk if this is good or if it can get better. I run 18lbs of boost at the track on E85, my WB isnt setup for ethanol so it still reads gas AFR.
