Been struggling with this tune the last few days. 6.0 iron block, bored .030 over, flat top pistons, 243 heads, cam, springs, flipped truck intake, 8.1 marine injectors.
First it was the injectors but I think I have them figured out.
I thought I had the VE and MAF pretty dialed, started to check WOT and I noticed a lean spot while holding around 2k in 2nd gear (on chassis dyno with 21% load). Best way I can describe it is that the cylair drops and then I get a lean spot, and p0101. Ive tired upping the VE table by about 10% in the offending area. Also added to the MAF table in the same general area. Tried different MAF and removing air filter that we thought might be restricting.
Thoughts? What am I missing? What did I do wrong?
2004 yukon 60 12587603 help.hpt
help.hpl
