Is it possible for ID850's to be maxxed out on an LS3 with a cam and 10psi of boost from a turbo? I finally found some time to start tuning now that the weather has improved and duty cycle is going over 100% when I turn up the boost. I thought I would have plenty of room with these injectors so not sure if something might be wrong with my tune.
Some background...
C5Z06 with LS3, 232/240 .629/.629 112+2, rear mount BW S475/83
ID850's & ECS Stage 1 fuel system
AEM Tru Boost Controller
3 bar SD OS with DSteck 2.5 MAP sensor
I have a 5 psi spring in the gate and boost controller set to make 7-8psi or 10-11psi. When I started to hit 10psi the car immediately went into REP mode (DTC 1514). To get around this, I ended up scaling the tune by 50% (reduced IFR & VE, and adjusted spark tables). Now it has no problem making 10 psi, but wideband is going lean around 5,000 rpms (3rd gear) and AFR is not responding to VE changes and inj duty cycle is going past 100%.
testing.hplWORKING TUNE2.hpt
