Speed-DensitySpeed-density is one of the most common methods of load control and airflow calculations. This method uses an equation relating the manifold absolute pressure (MAP) and the intake air temperature with the known
volumetric efficiency characteristics of the engine to calculate airflow, and thus makes it possible to calculate fueling requirements. While this method is not as robust and flexible as the MAF approach, it is not as sensitive to placement, errors and limitations in range, and in some applications can calculate airflow almost as accurately as a direct measurement. Speed-Density systems also have the benefit of not requiring an obtrusive sensor directly in the intake stream, as the MAF sensor can often actually impede airflow. The cost of implementation of such a system is also significantly cheaper. In speed-density systems the
volumetric efficiency must be known and recorded in a reference table and will be used in air flow calculations. Using the universal gas law (PV = nRT) it is possible with the MAP, IAT and volume filled to calculate the mass of the air. This method is simple, but accurate. With the mass airflow now known fuel requirements can be calculated using the same equation used with the MAF method.
Speed-Density systems are very sensitive to temperature changes. As such, it is critical to pay close attention to temperature correction factors. This is due to changes in air density at differing ambient air temperatures (recall the VE and MAF equations use density at standard temperature and pressure.) Speed-Density systems also require more time to calibrate, as the entire V.E. table must be programmed into the ECM/PCM, and will be affected by engine component changes, especially parts that drastically change airflow behavior such as forced induction, cams and intake manifolds. Care should also be taken to ensure the VE map is as smooth as possible while maintaining adequate air/fuel ratios. An additional drawback with Speed-Density system can be a decrease in airflow resolution (sample rate) due to the calculation in lieu of direct measurement. Note that installation of forced induction or large increases in boost may also require the MAP sensor to be upgraded to a unit with a higher range.
