Results 1 to 8 of 8
Thread: Camaro 6L80E in a Caprice
    Oct 2016
    SW Michigan
    7
    So the trans is shot in the 2011 Caprice. I can get a deal on a 2010 Camaro 6L80E. Can I Write the Caprice file to the Camaro trans w/HPTuners or does this require a trip to the GM dealer?
    13,564
    If you are lucky and they have the same TCM OS you might be able to do it with HPT.
    A member recently did that with is truck.
    http://www.hptuners.com/forum/showth...ght=6l80e+swap
    Oct 2016
    SW Michigan
    7
    Thanks for the reply-
    So if the OS is different, GM dealer can change thhe OS?
    Jan 2004
    Perth - Western Australia
    276
    you can always pull the tcm out of the original trans and put it in the new one
    Oct 2016
    SW Michigan
    7
    Alright, I appreciate the help w/this.
    Jan 2006
    DFW
    249
    I did this with my denali, but both were same year trans, out of the same model, therefore same OS. I did successfully do a write entire with the original tune and everything and worked well. Not sure if it can be done with other years/OS mismatch. I would try it first, if it didn't work swap the tcm/valve bodies. I would try to flash before you added fluid. I actually hooked up my trans connector with it sitting on the jack and did everything before I bolted it in, incase I had to swap TCMs. Good luck.
    2008 Denali XL AWD LSA Blower
    2010 CTS-V
    2005 LLY Duramax SAS
    2015 Denali
    Jan 2006
    DFW
    249
    The deal can for sure change the OS with their techII by the way. That was my backup plan.
    2010 CTS-V
    2015 Denali
    Oct 2016
    SW Michigan
    7
    Awesome, thanks!
