boosted.hpl 98 ta 99 pcm twin 61mm 8psi stock motor 42lb injectors @ 58psi stock pump.hpt
98 trans am, 99 pcm upgrade. 450 pump, 42lb injectors until the 80s arrive monday. Stock 5.7 ls1, twin 61mm on 3 turbos w/ tt intercooler.
Only have a few drives with it have updated the ve 2x now and did some hand smoothing.
I have wideband plugged in and can do afr error with it but i really feel like the wb isnt recording properly in hptuners. At idle it seems pretty on point but in boost and decel it sure seems way off. For example if I get into boost wideband will show 11-11.5 and hptuners shows wideband a lot lower than that. Ive looked at my forumlas several times and just dont get it. Gauges are grounded to battery and have their own relay setup. So for now I am just using stft and keeping an eye on the wideband when I hit BE.
Wideband is innovate mtx-l
programmed 0v = 10.0 5v = 18.0
([7101.10]/.5)+8.5
100*((([7101.10]/.5)+8.5)-[50121])/[50121]
