Results 1 to 12 of 12
Thread: Tuning running rich
    Feb 2017
    defiance ohio
    13
    Tuning running rich
    Haveing some rich 5.3 running issues...first off was stock motor, pump etc ran rich then and now still rich after new fuel pump shaved truck intake msd wires, btr stage 3 218/224 113 +3 cam, btr dual cm .660 springs, 7.40 cm btr pushrods, ecm was a stock base tune from coolmike on frebay.. has 02s delete etc.. not home roght now so cant post a log but have been getting it better and just hooked up aem wb first readings was mid 12s after messing with afm etc etc got it running better more power better rev etc and im now in mid 13s but still running rich any info or anyone that has a similar tune file for my kinda setup i could copy n play around with
    Feb 2017
    defiance ohio
    13
    my tune
    this is where I'm at now on my 5.3 will work on getting my wideband sorted out to log with
    Nov 2009
    All Around
    3,149
    log?
    Feb 2017
    defiance ohio
    13
    log
    heres my log with that tune this was mixture of park and drive run while holding brakes cold here and truck is still in bodywork stages so cant drive down rd yet wideband was reading avg mid 13s
    Feb 2017
    defiance ohio
    13
    shoot that's not the right log I must have not saved the one I wanted to
    13,582
    Are you running o2 sensors on this setup?
    When you get a log file, you need to log more things. Make sure to include injectors, fuel trims both short and long term, knock retard, commanded air ful ratio.
    Tuning the both your VE tables and the MAF curve is likely the best place to start here, get light throttle and medium throttle under wraps first and then work on WOT fueling.
    Feb 2017
    defiance ohio
    13
    No 02s how do i get injectors and everything else to log also?? Sry im new to this
    13,582
    You should at least run front o2 sensors, they will make tuning and closed loop functions really nice for cruising around and getting some decent MPG's.
    If you never going to run o2 sensors you must let the computer know that. You need to disable all o2 sensor codes for front and rear bank. Disable cat over temp (COT) in the tune. Disable all closed loop functions and all STFT and LTFT functions. This way it will run in open loop only.
    Just add the channels to the main channels list to get injectors, commanded air fuel, knock retard etc etc . Right click to add them.
    Feb 2017
    defiance ohio
    13
    ya I wish I knew then what I kno now lol I plan to add 02 wiring in future
    Feb 2017
    defiance ohio
    13
    heres a log think wb shows up now
    log 3 with wb.hpl mixture of park then in gear while holding brake....think I got wideband reading now just need to figure out how to add a gauge to log screen but it show wb readings on side and matches what my gauge in truck reads
    Feb 2017
    defiance ohio
    13
    tuned for no 02s, also not sure about cot but the closed loops stft and ltft are disabled
    Feb 2017
    defiance ohio
    13
    Cot was also disabled already
