I am in the mists of getting the VE tables in order and one thing I have noticed is fan 1 and 2 is coming on at like 100* for what seems like the minimum duration of fan operation in the tune. This also irritates the car as the additional load from the alternator on the cold engine almost makes it die, but doesn't. This will affect me tuning (trying to tune) the Base Running Airflow table if I forget to manually disable fan 1 and 2 operation. Is this normal for SD tuning?
Attached the tune file.
Have not tuned the MAF or Base Running airflow yet either as the VE needs to be close ironed out. I have only been working on idle to 2000 rpm after realizing my engine builder set the cam an additional 4 degrease advance . I wound up having to peel it apart and time it dot to dot. I didn't degree it as I didn't have the tools to do so.
If I am missing anything, tune setting wise for the fans, please let me know.
thanks!
