OS 12639835 Warning
Hi everyone!
There is a bug in HP Tuners all versions i've tried (2.24, 2.25, 3.0, 3.1, 3.2).
Do not modify:
- Speed Limit Str Fail
- Speed Limiter Minimum
in calibrations with OS 12639835.
If you look carefully in Calibrations Details you can see OS CVN changes with those parameters modification. So you can easily corrupt OS and brick ECM if will do Write Entire.
HPT Employee
Please email your file to support and we will look at it.
You can take any file with this OS.
For example, from tune repository:
https://www.hptuners.com/customers/t...wnload&id=1505
