Lurked on here many times but I finally have a question I'd like a concrete confirmation on. I'm working with a 2008 e38 that is hard coded to max out at 63.5 lb/hr. The car has h/c and e85 so it wont ever be boosted but I'm trying to scale in some of the new ID1050X using the stoich and ifr trick. The problem is that if I just double the stoich and half IFR I still am over the limit in a lot of the ifr table, I cannot also scale more than 2.18 because at that point I reach the 32 limit of the stoich table.
So heres a screen shot of what I did. I scaled the stoich by 2.15 to leave a little room down low and then applied the same ratio over the IFR table. It still does flat line way up top though. owever heres where my question comes in, does that even matter being NA? 58psi is 400kpa and assuming a worst case pressure differential it pushes to 500kpa. In that case all the cells that are flat lined shouldn't matter correct and I'm ok to run as is?
Thanks for the help
