Results 1 to 3 of 3
Thread: looking for help transfering injector info from Greg Banish spread sheet to tune
    Mar 2010
    227
    Im trying to transfer the data from the spread sheet to the tune on my 2001 fbody. The info on the spreadsheet for the injector offset manifold vacuum is in multiples of 10 and the tune has multiples of 5. Do you just use what you can and interpolate between?
    1993 reef blue Mustang coupe
    Ls1 conversion
    1 7/8 cooks headers
    AFR 205 heads
    Fast 92/92 intake
    PAT G./ EPS Custom cam 230/234 .600”/.602” 112LSA +2 advance
    century Built 4l60e with Circle D 3500 converter
    4.11 gears
    That is exactly correct. Copy and paste all of the 10 values, and then just interpolate between the 2. This is the correct way.
    Yes, that is the correct method. Past all even and interpolate.
