Page 2 of 2 FirstFirst 12
Results 21 to 35 of 35
Thread: Question about Flex Fuel / E85 Tuning
    Tuner dreksnot's Avatar
    Loveland, CO
    147
    Alcohol PE timing adder DID add the full 6* of timing, as shown in the logged full Timing Advance, and definitely felt and dyno'd like it should have (when tanked with E80, as I expected to according to my Multi table). But, the add appears to be either zero or full amount from the PE table, and the Multiplier didn't appear to have been used (no effect) for partial percentages of ethanol. All or nothing - so, I believe the lesson here is to be careful when running a blended tank, using a FF sensor, and aggressive E85 timing. I know this to be true for the PE adder table but have yet to see if the Multiplier DOES affect the values in the FF Spark Table.
    The PE timing add should be 4* (6* from the PE table multiplied by 0.667 from the Multiplier table) - but it's not.
    2013 Camaro LSX433 with TFS 245cc cat heads
    AGP 65/65 Twin Turbos into BTR Equalizer intake
    BTR 237/247 .610"/.601" 116+5 (10* overlap) cam
    ID-1700x on AGP Fore Triple w/ Flex Fuel sensor
    Cortex EBC | n2mb WOT box | custom anti-lag
    Tuning Addict
    6,852
    I've never seen the multiplier table get applied towards the regular A/F alcohol table - it will apply toward the regular flex fuel spark table fine though...
    It's a non running log, but you should get the jist - I have 6 degrees "I think" in the table where this is referencing...
    ~Greg Huggins~
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Quote Originally Posted by dreksnot View Post
    Yeah, don't use that table. Try the flex fuel spark table instead. Should be down at the bottom right on the same page the mult is on
    And you'll need to log alcohol or ethanol advance also
    Tuner by night
    CPX Tuning
    2005 Corvette, M6
    ECS 1500 Supercharger
    2007 Escalade, A6
    Stock
    Loveland, CO
    147
    Just saying, this is what the HPTuner description claims it'll do. (see tiny picture below)
    Loveland, CO
    147
    Already populated my FF spark table with a stock 6.2L FF vehicle table I found in the Repository, along with some slight modifications, and zeroed out the Alcohol PE table. When in boost and PE, I should be at the same timing as I've been running "safely." It's been entirely too cold to tank up with E85 so I'll have to see if the Multiplier has the proper affect when I can tank up and log.
  6. #26
    Moderator
    Mar 2014
    Raleigh, NC
    6,343
    Ah give it a go in the cold, it should still start. Or at least mine did with E80 in 20'ish degrees. It did turn over a bit longer than normal though
  7. #27
    Senior Tuner DSteck's Avatar
    Mar 2008
    St. Louis, MO
    4,860
    I use the PE adder with zero issue and have no problem sliding timing according to ethanol content.
    I'd suggest revisiting how you set up the bias table.
    http://www.dsxtuning.com
    Just say no to bull s***.
  8. #28
    Tuning Addict
    6,852
    Any suggestion for the biasing table Dave?
    ~Greg Huggins~
  9. #29
    Loveland, CO
    147
    Well, when I installed my FF sensor, I asked if these tables needed to be populated:
    Engine>Fuel>Transient>Evap Factor Blend
    Engine>Fuel>Transient>Transient Fuel Mass Gain Impact Factor>Blend
    and
    Engine>Spark>Advance>Spark Correction AFR Correction>Multi vs. Composition
    The answer was No, No and Yes. Suggestion was 0,0,0.2,0.5,1 <<< since I can get E75-80 regularly (and 91 is E10), I changed the values to 0,0,0.67,1,1 (plus I've heard anything over E60 runs the same... so far, that's what I've seen out of my experience).
    I did that, then at some point, figured (being Mr. Smartypants) it wouldn't hurt to populate the other two tables with 0,0.125,0.25,0.625,1 <<< I wonder if populating those two other tables messed with the overall resultant... and that's why I get an all or nothing spark add?
  10. #30
    Oct 2013
    Denham Springs, LA
    146
    From what i learned and have seen from multiple people.
    The other stuff mention i followed from a 2012 Holden Cal that was Flex fuel. With that said, i'm trying to narrow down WHICH table needs to be populated for correct Flex spark tuning.. which seems like its "flex fuel spark".. The AFR correction table, Gas and Alcohal are adders while in PE/COT... So your high octane table + your Alcohol table = total spark while in PE which is how i understand it. But if E85 goes to E40 and nothings in Flex fuel spark, what happens?
    Basically i'm asking WHICH table needs to be modified for spark control if i have my comp setup.
  11. #31
    Australia
    1,990
    so far im only using the flex fuel spark table and it seems to be working fine, but looks like there are a few options if u set up main spark for petrol then add to flex spark for ethanol then u could also use the PE/COT adder table for PE with an increase for petrol in one table and ethanol in the other with the flex composition between them both if u added more to the ethanol table, so looks like the mult v composition isnt for the actual use of added timing for flex it for going from the PE/COT petrol table to the PE/COT Alcohol table..?
  12. #32
    Oct 2013
    Denham Springs, LA
    146
    There's multiple ways to skin a cat, i get that, i just want to understand all ways. Thats all.
  13. #33
    Aug 2014
    Central, LA
    737
    I may have to play with the spark advance correction table, but honestly it seems like a simpler way to get timing added with flex fuel than messing with the whole flex fuel spark table. I've never messed with it, but I'm assuming the row axis is the same EQ ratio as the PE table (meaning 1/EQ = commanded lambda).
    I feel like you'll get similar results either way but you lose some granularity with the spark advance method...not that it probably matters since most people just add a flat amount of timing (within an rpm range) with the flex fuel spark table anyway.
    I setup my comp table like this because we usually get ~e70 around here out of the pump and I figured to tune around that comp vs anything higher.
    0,0,.6,.9.,1
  14. #34
    Tuning Addict
    6,852
    You might want to lower the .9 to .75 or .8... Unless your just looking to add full timing for E60 to E70, which I guess was your point...
    ~Greg Huggins~
  15. #35
    Aug 2014
    Central, LA
    737
    Yeah that was the goal since that's about as high as I'll ever get out of our pumps, and if I do it won't surprise me by adding more timing than I'd want.
