Just installed a dedicated motorsports flex fuel kit, really easy to install works great as intended, the car is a 2010 camaro SS auto, it has a vararam intake, headers, no cats, 3" exhaust, tsp vvt stage 1 cam, circle D 3400rpm stall, today after i tuned it with E40 (40% ethanol) it put down 437whp and 421 wtq, since i couldnt find this info on any thread i will post it here so anybody searching for this info before doing the conversion (like i was searching) finds it, at this power level stock pump and injectors cant handle E85 the E40 mixture is the most it can safely handle according to my opinion at this moment(on straight fuel inj duty cycle was at 63%, on full E85 it went to 115% and fuel pressure droped to 37psi, on e40 is at 89% duty cycle).
Now, on to my questions:
1- Other threads on flex conversion use the data from a 6.0 australian car, i couldnt find it in the repository, so i used a 5.3 tahoe for the evap factor blend and the impact factor blend, left the other tables as they where since they where populated already, but i dont know if this can get better by using other info, or if the 5.3 values that are very different would work OK?
2- The car is stalling on decel, it was ok on straight fuel but couldnt drive it on the streets as it was since it would stall each time i let go of the accelerator, used the flex fuel timing table from the tahoe and it made it drivable, but it will still stall and then bounce back into its normal idle rpm, how can i fix this?
3- my fuel pressure is droping to 51 psi (its doing the same on gasoline and E40) will i be ok or is it on the limit of what the fuel pump can flow?
4- Im getting burst knock when i put the hammer down, tried decreasing the mult vs rpm where i was getting burst knock, but that didnt work, how can i get rid of that?
5- the car seems to stay in Open loop all the time, since it has no cats i deleted the codes for the rear O2s and the cat, but im still getting them on the scanner, how can i fix the open loop part, and is it normal to still get the codes from the scanner?
here is my tune and a couple of logs:
camaro 2010 E85-3f.hpt
flexdyno4F.hpl
flexdyno3F.hpl
