I have a 2009 6.0L truck engine and 6l80e trans along with the ECM and TCM. I installed a LSA blower on it and need help with the tune to get it started and running to take it to the dyno.
I copied a few tables from an LSA camaro such as the injector flow rate vs press, MAP sensor linear and offset and the SC inlet pressure sensor linear and offset into my tune. The MAF is a OEM LS3 airflow sensor.
I deleted VATS and such since its a swap and I am getting crank RPM on the scanner but it will not fire up. I was wondering if I am missing anything?
Here is my tune file that I am working with:
PCM-1009 TEST TCM 6L80E LSA INSTALL MOD.hpt
If I need to post a log fill of it cranking let me know and I can scan it and post.
